A few years back set_status_text stopped working in LightUp while its building geometry and the process takes a few seconds. For 10+ years prior it worked just fine but I think around the time the Trimble engineering refactored to run the window/display in a separate thread perhaps(?), it doesn’t update until your Tool returns from the UI::Command block its executing.
Before I dive into Qt + Windows messages and bend this to my will to make it work:
Has anyone else seen something similar?
Is there a way of forcing the SketchUp window to repaint? I’ve tried sleeping for 10ms (ie yield to another thread), invoking View#invalidate with no success.
There is view.refresh which forces an immediate invalidation of the viewport and thus a drawing of the view.
However, the status bar seems to be handled differently and should update with tool#set_status_text, except when you are in the middle of a long calculation.
It is unclear however, because it used to work in the past, when I was using a cheap progress bar but doing putsof ‘.’ to show the progression (I now use a true progress bar and slice the long calculation into small chunks to give back control to view.refresh).
Since the migration to Qt (SU2023 on Windows) and the subsequent releases, there has been impact on the refreshing of the viewport. For instance, in SU2026, puts seems to be sligthly asynchronous so that the view may refresh.
There is nothing documented, so any behavior can change in any next release.
FYI, there is no Tool#set_status_text method. It is a method of the Sketchup module.
As I recall, the status bar seems to be updated whenever the mouse moves. Setting it’s text can be done in Tool#onMouseMove or in the tool’s #draw method.
My mistake, I shoudl have written Sketchup.set_status_text
When you are within an active Tool, you can call it wherever you want, for instance within a calculation loop, regardless of whether you move the mouse or refresh the view. In principle in should update on the screen, except that if the calclation is long and intensive it does not.
No, its not a focus thing, the Sketchup window is the active window.
Its as if the redraw code is just never invoked.
Agreed. The reality is it does not work great and there is almost no documentation as to what the “limits of use” are. As I said, sure, I can reverse engineer anything - I just wish I didn’t have to.
Is there anyone on Trimble team who could shed some light on “How do to make the status bar redraw”?
Didn’t work - and honestly, I really dont want to descend into having N asyncronous timers firing off.
I have a Tool that when selected, processes the geometry and begins rendering. It continues until another Tool is selected. Surely that is a use-case that the SketchUp status bar can handle, right?
Dan, there is no drawing or onMouseMove during processing. I used to show progress in the status bar by calling set_status_text from within the C++ processing - which worked fine. Now it doesn’t.
I can’t remember the details on the top of my head but I have had issues with setting statusbar text outside of my tool as SketchUp updated it right after. I used a 0 timer as a workaround to make sure mine was the last to be set and at least back then it worked.
That said, it’s quite hacky. I’m not sure if statusbar texts are even expected to be set outside of a custom tool.
This might indicate that the API is checking the call stack to decide whether to honor the method call to set the status bar text.
So a workaround could be to have the C-side change the progress text held in an instance variable and then call an instance method of the tool that displays the progress text by directly calling Sketchup.set_status_text from within that method.
FYI, sorry I now realize it was onSetCursor() that is called whenever the mouse moves.
EXCEPT, that a UI::Command object is NOT an abstract Sketchup::Tool object, so no the assumption that it should work from a command block is incorrect, if the engine is checking the callstack (or by some other means) to determine that the call is truely being made from within the current active tool.
We are confounding some situations probably, (but even Julia reinforced this idea above.)
There are documented API methods that are only to be used within a tool object.
Things have changed over the years and some methods have been restricted where before they were loose in use.
You have proposed the fact that Sketchup.set_status_text has differing behavior that it used to. I agree, that the behavior has changed at least once in the past. I.e., at one time when we moved the mouse through the menus or toolbars, the status bar text would display the UI::Command description. But this changed for a few versions and did not work. Then it was fixed again.
I KNOW that if you use an API method to set the status text OUTSIDE the active tool object (say by executing a statement in the console,) as soon as you move the mouse within the model client area, the status text is reset by the active tool (be it native or Ruby.)
Also, when hover in the menus or toolbars, you see the command description until the mouse is moved back into the model area or moved out of the menus or toolbars. Then, the active tool takes over the status bar again. Therefore, the active tool has priority over the status bar text.
I have proposed (emboldened the “if”) that:
Perhaps the method has been restricted in recent releases to only a currently active Sketchup::Tool object, as it’s use was mainly “owned” by the active tool object (be it native or Ruby.)
I posted above a pure Ruby tool for test and it acts according to what I would expect.
So the problem you see, might only be with use of the Live C API ?
We have not heard from the devs as they do not stop in here much anymore. I’ll try to ping @bugra
Sketchup.set_status_text does not work at all, even on the first call?
or Sketchup.set_status_text does not update the text after some time while your processing method runs?
By the way, Sketchup.set_status_textcan be called from anywhere, within or outside a tool.
Simply, when you think you are outside of a tool, you are actually in the native Selection Tool, which happens to update the status text bar at each mouse move, like most interactive tool.
You can make the test: If you have an interactive tool which is NOT calling Sketchup.set_status_text, then you can perfectly call Sketchup.set_status_text from the Ruby console and the text will stay on screen indefinitely while the tool is active.
Adam, if I understand this right, you have a long-running Ruby method that synchronously tries to make set_status_text calls without yielding control back to SketchUp. I honestly wouldn’t expect such a thing to work at all in a single-threaded environment. I know that this sort of thing worked when you used Win32 common controls with progress bars and status bars. I never really understood why that worked honestly. Windows must have been making sure that part of the window is updated even though the UI thread is still busy (?)
I am not a Qt expert at all. But like I said, my default expectation would be any UI painting would not work when the UI thread is blocked (by your code in this case).
