Hi! So I’ve been using sketchup for about 6 months now, and this isn’t the first time I encountered this problem or feature that I just don’t know. My select tool selects through walls even without Back Edges enabled. The first time it came it just fixed it on its own, I don’t know how. I’ll add a picture to show the problem. Does anyone know how to fix this? Also, it’s not just this file that’s like that, it also happened on other files when I tested it
Hm you guys are right I think, I just saw a thread with the same problem and the video that was the solution said it was normal. Thanks! I might’ve just not noticed it before
This native window_selection behavior is normal and has always been like you described: all geometry within the window from what you see to infinity through faces etc.
There certainly might be a plugin that allows you to only select the foreground geometry, not what is currently behind other geometry. You’ll have to search the “selection toys” plugins, Thomthom’s plugins maybe?
For the benefit of readers who may stray upon this topic: the behavior the OP describes applies only when you use a selection box (click and drag out a box to select entities). It does not happen when you click on entities one at a time to add them to the selection. This is the way the selection tool’s boxes have alway worked, they consider the x,y extent on the view but go to unlimited depth into the view.
