Section fill
Has anyone come across this behaviour before?
In setting up my scene, I chose section fill but not all cuts are filled. Could this be because I have some bounding lines hidden? If so, what do you do when you want to hide lines but want fill to work properly?
I’ve seen this when some edges are either missing or not in the same context. Do those walls have faces top and bottom? The one under the upper window at the right doesn’t appear to have a bottom face but that could just be the angle of the view.
Yes, Dave, you’re right. I think in the process of hiding lines I somehow managed to delete bottom surfaces of some elements. All present and correct now, thanks.
