Scrapbook reset
Hello
I have a feature request for LayOut - what about making an undo butom/option in the scrapbook section - so that it´s easier to manage your costom scrapbooks
I find scrapbooks useful but theres no option to reset ti original or delete scrapbooks
kind regards Camilla Bonde
Scrapbooks are simply LayOut files. You can go into the folder where they are saved and delete the ones you don’t want. You can see the path to the scrapbooks you are using in Preferences>Folders>Scrapbooks.
Copy the User path into File Explorer and you can delete the scrapbooks you don’t want.
If you’ve modified the original scrapbooks, delete the Scrapbooks folder from the ProgramData path. Then rerun the SketchUp installer.
Note the Restore Defaults button in LayOut Preferences>Folders only restores the default paths.
Thank you for your help, but where do you run the sketchup installer??
Presumably you’ve kept the installer for SketchUp in your Downloads folder. If not, sign into SketchUp and get the latest copy. Right click on it and choose Run as administrator. If prompted choose Repair.
