Scene style for all objects?
Hi there, I’m working on making a bedroom but first I just wanted to point something out: I downloaded some book models from the warehouse and I had a laugh about how all the books are architecture-related :laughing:
Anyhow, I downloaded some basic models to fill up the room and I noticed how some models don’t conform to the scene style I selected. I’m going for a look with all of the outlines present, but I noticed that some of the models don’t have the edges even though I set the edges to ‘on’ in the styles menu. Why is that, and how do I fix it?
You will need to upload the model in question to be sure, or provide a link to its warehouse location. Best guess is the model you download has the edges hidden. Setting a style without edges is a global choice; but hiding or softening-smoothing individual edges or batches of edges are different tools and those will stay hidden unless they are unhidden manually.
My guess is the edges were softened / hidden in the component you downloaded. You’ll have to edit the component to make them visible… but… just a guess here - like most anything on the warehouse this probable means that the objects were created in other software and softened or hidden because there are a gazillion surfaces.
There are a couple of different models but one would be this printer: Trimble Identity
Share the actual model, not a link to it. You can drag it onto a reply.
Printer.skp (553 KB)
The author of that component hid a lot of edges.
Select the geometry in the component and choose Unhide.
Is there a reason you have Profiles set to 6?
Printer unhidden.skp (325.2 KB)
I just increased it to that so that I could see if the profile would show up even if I made them huge
Thanks!
As long as the edges are hidden they wouldn’t show.
You’re welcome.
FWIW, the general wisdom regarding using objects from the 3D Warehouse is to download them into a separate SketchUp session so you can examine them for suitablity and clean them up if needed. Don’t add them to your project until you have sorted them out.
