Scaffold design
Hi
Im trying to design scaffolds for my business. These arent proper designs just rough ideas how to build for my employees etc
I have the ringlock components but i am finding it hard to match the components in correctly. There are certain holes were the ledgers and transoms go and they seem.offset and dont match up. Is there an easy way to do this?
using sketch up pro 2024 on a laptop
Regards
Lee
Post the SketchUp files so we can figure out how to best guide the process.
You could utilize Snaps to add points to the components so they can be placed together easily.
Thank you for the input. Will try this and get the files uploaded as recently left the office.
I have designed scaffold systems in SketchUp. Make sure you have a clean scaffold file with a balanced bounding box on the components so you can use corner and center snaps effectively. Make sure the dimensions are correct so you can type in moves, and use inference locking and copy/move arrays to help build. Example: single level set with floor boards, copy/move with blue arrow for vertical lock, type in level height ie 7.5 feet, then type x5 for five more levels. Arrays are your friend.
Snaps take a while to set up initially but can make the work very fast.
There are some extensions… perhaps it helps (never tried it myself.)
https://extensions.sketchup.com/search/?q=Scaffold&f=home
Hi everyone
As a newbie i gave it my best go but its no mean feat.
Snap worked alot better with a few adjustments and making a having to make each back individually. Copy. Past etc instead of duplicating it many times.
Also finding it hard to get the boards on the bays and the next lift to line up correctly
Seen some videos on older versions were they group components together and x6 and works out nicely
Is a little messy for compared to the pros
2garfield.skp (14.6 MB)
You could benefit yourself by spending some time at The SketchUp Campus. This is a site that will provide the basics for learning the SketchUp modeling process. Also, spend some time at the SketchUp SketchUp YouTube site. It provides much information including how to use each tool.
Hi
Yes thats a plan also. At moment currently on a vessel which only gives 1gb per 24hours and youtube is banned.from the wifi
In the meantime ive just been trying to mess around with it
Kind Regards,
Lee Howarth
LCE ACCESS LTD
Associate Members of The Scaffolding Association
