I’m trying to save multiple monochrome scenes
but I’m having difficulty when changing the North direction because it also changes other scenes as well.
I understand that shadow doesn’t behave that way since it makes the position of the shadows to fixed direction but how can I achieve this in monochrome mode?
Thanks in advance
DaveR
May 9, 2022, 8:24pm
2
What version of SketchUp are you really using?
Do you have Scene transitions enabled? Try disabling them and then make the scenes.
Are you using the Solar North plugin?
I’m using Sketchup 2021, when I turn off the transition it works,
but If the transition is turned off in rb code, it doesn’t seem to work
DaveR
May 9, 2022, 8:37pm
4
revyiver:
Please correct your profile, then. It shows you are using SketchUp Free (web).
Yes. That’s normal behavior.
Are you using some plugin to control transitions? If so, what?
I’m using my plugin to control transition
model.options["PageOptions"]["ShowTransition"] = false
and code runs through saved scenes and create monochrome scene for each one
and then it turns on the transition again
model.options["PageOptions"]["ShowTransition"] = true
DaveR
May 9, 2022, 8:45pm
6
It would have been helpful if you’d have mentioned that in the first post. Please move your thread to the Ruby API category.
Ah ok sorry about that I’ve moved it
You likely need to set each scene page to use it’s own ShadowInfo hash.
See: Sketchup::Page#use_shadow_info=
Once this is set, for each page set the NorthAngle and update the page.
Now when your code (or the end user) switches scenes they’ll see the NorthAngle change as well.
