Save a selection
Hello
Maybe I’m asking too much?
Is there a way (an extension) to save a selection?
A bit like in Photoshop where once the areas have been selected, we can memorize it to be able to reuse it later.
If not, would creating an extension be possible?
Is there a better section for this kind of question?
Thanks
photoshop exemple
select
What are you selecting? How do you want to save it for later? For use later in the same model? Or for later use in other models?
If you make a component containing the selection it can be saved for use in later models.
Depending on what you are trying to select, it may be that you could tag the entities you have selected.
you will be limited to those “selections” only being able to have 1 tag.
What is your use case for wanting to save a selection?
Selection Memory | SketchUp Extension Warehouse = tt_selection_memory | PluginStore | SketchUcation
selection_manager | PluginStore | SketchUcation
Smustard™ - the Companion to Sketchup™ - SelectionMemory
Smustard™ - the Companion to Sketchup™ - SelectionMemory2
Thank I’ll take a look
from example
2022-10-27_08-55-47-678
it could be handy in some situations
but maybe dezmo gave me the solution
Why don’t you just make a component of that and save it in a collection for later use? That doesn’t require any extensions.
Thom did this extension that remembers the last few selection changes:
https://extensions.sketchup.com/extension/6fa33ac4-2aa7-443b-aa4b-a211d7af8b03/selection-memory
You can also use Copy (CTRL+C) and Paste (CTRL+V) for reuse in the same model.
