Can I undo a select or deselect? Or, what do I do if I mess up a complicated selection?
Let’s say I’m carefully selecting some complicated set of faces. I’m familiar with the various ways of doing that efficiently. But once in a while I’ll make an accidental click outside of my selection and the whole thing goes away. Is there anything I can do in this instance to get my selection back? Or do I have to start all over?
If I Undo, it just undoes the last actual creative decision, does not effect the selection process.
Check this plugin: Selection Manager .
I’m not sure how to install this. I downloaded the file from your link and they instruct one to just put the text file in the “plugins” folder, but my installation of Sketchup did not add a Sketchup plugins folder. Do you know how I get this to run in the application?
Plugin is a bit old, so you need to do it manually. (notice this file is .rb, -i think- newer ones have .rbz which allows you to auto-install via SketchUp)
Copy the plugin to here:
C:\Users\YOURNAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins
then you’re good to go.
Or better yet, download it directly from the Extension store.
or a more recent one
You can also try TomThom’s Selection Memory. Extension | SketchUp Extension Warehouse
Interesting topic, thank you all.
Thanks for all the helpful answers!
