Rotating Embedded Objects in Subgroup
Hey might SketchUppers!
I have a component (parent) with a subgroup and an object in that subgroup, and I want to rotate that embedded object based on the RotZ value of the parent! I can get it to work on the original but it loses that functionality in any copy of the component! I’ve tried redraw but that doesn’t seem to affect the object!
Is there a way to ensure this rotation maintains function in copies?
Use Enroth’s “deep make unique” extension (via right click menu) straight after copy.
If this fails, can you upload a dummy DC to match the problem,
I worked out that when a panel is turned, we can just change the panel height after the turn and then change it back. Easy! Seems DC need to do a full process re-run!
