I have created a dynamic component that has a set of copies in it, i would like to rotate each of the copies around their individual red axes. when i change the rotation attribute of the original, it will rotate, but the copies remain un-rotated. if i then go back and change another attribute that controls the number of copies to a greater amount, the new copies are rotated, and the original, but not the original copies. then if i change that attribute again, so that there zero copies, and then chance again to the quantity that i wanted, finally they will all be rotated. there must be a better way.
It sounds like the issue is that the copies aren’t Redrawing when you rotate the original. But when you change the amount of copies, it forces a redraw to the new ones.
I’ve had a similar problem before, never fixed it, I asked around and someone suggest you use the Current function. I never got around to figuring it out, but try making a new Attribute with a Currrent(rotation) and then have the original Rotation references it. It’s just a guess, but it’s all I got.
As soon as I read the first line of your post, I knew what was wrong. its not redrawing. of course you can force it to redraw by right click, dynamic component, redraw. this worked, but why wasn’t it doing it automatically? I didn’t mention in my original post that I had not yet added a custom attribute to my component, I was just changing the rotation attribute manually, and when I tab out of that field, it dose not force a redraw. however once I added the custom field, and changed it via the component options window, once you click apply, it dose force a redraw. problem solved. I included the model anyway, thanks for the help.
