Rotate multiple entities whilst holding z-value
So here’s my issue…I’ve got a bunch of groups that need to be rotated 45 degrees but holding their bottom position the same…so not rotating everything at once from one central point - instead rotate each one at once from each one’s center or bottom point.
See below. Any extensions that can do that? I’ve tried CLF Scale and Rotate Multiple and FredoSketch with no luck yet.
Edit: I can’t use components because each group is unique…the example below is a simplified version to illustrate the ask :slight_smile:
Might have posted too soon…further searching showed me ASM SpinUp! For anyone who may later ask the same question.
