Hi All,
I am relatively new to SU but I have a solid CAD background. I mainly want to design furniture and home projects. When I create a curved face it is composed of parallel lines that shows the profile but doesn’t look realistic. How can a I change this to make it look more real. I have a feeling this has a simple answer. Thanks!
SketchUp represents curves with a series of short straight edges segments. Depending on how you create the curves, you may be able to increase the number of edges segments to create smoother looking curves. You can’t get away from the short segments, though. Usually it won’t be a problem and for smaller objects, even the default number of sides in the various curves won’t be a problem.
While it might seem like you’d always want to use the maximum number of segments in curves, there are situation where you won’t want to do that.
Thanks! That was what I needed.
Thanks! That made more realistic curves faces. I thought it would be something simple. I just needed to know where to look.
good video that explains a lot.
