Remove lines from Offset without have to use erase on all
How can I remove offset lines. See attached.
Do you want to remove them completely or just hide them? What is the end goal? Are you wanting to remove the inner edges of the outer ones?
good question.
Sometimes both options.
Right now delete completely.
Thank you for responding
Select the edges you don’t want and press Delete.
In the case of the third L, once you’ve erased one of the outer edges you can triple click with Select on the remaining edges and delete them.
Are you still using SketchUp 2021?
version 23.0.419
It will not let me use Sketchup 24
Oh Ok, I was tryin to avoid that as I will have many curved line to delete manually.
Please correct your forum profile.
Why not? If you have a current subscription you should be able to use SketchUp 2024.
If you triple click with Select on one of the remaining edges you’ll select all connected and then can delete them in one go.
edges
Ohhh My Goodness. You Rock!!!
Thank you soooo much!!!
For the benefit of newbies and to complement on Dave’s post, you can use this procedure:
1 - Delete the faces to keep only the loops of edges.
2 - Triple click on any of the edge on the loop that you want to delete to select all of it.
3 - Press the Delete key.
4 - Redraw any of the remaining edges to close the remaining face.
It seems you could benefit from this video: https://www.youtube.com/watch?v=O81znFiVeRQ
