I would like to create a pad that follows the same plane as the main pipe. My idea is to offset the branch pipe line by 200 mm, but I haven’t been able to achieve this using the standard tools.
Could you please advise me on how to do this or suggest an alternative method?
This is very rough as a quick example. I used Intersect Faces between the main and the branch. Then I used Offset of Surface from the Tools on Surface extension to outline the pad. Joint Push/Pull to give the pad thickness. If I was seriously modeling this I would use more sides in the circles for the two pipes to get smoother edges for the pads.
Here’s a method that doesn’t require Tools on Surface. In this case I made the pad as a separate component so it can be easily copied to other pipes. In the interest of time I didn’t spend any time on real dimensions.
Thank you very much. There’s no need to make the video clip anymore. I was able to follow your instructions successfully. I really appreciate your help and guidance. Thanks again!
Thank you very much for taking the time to explain the process and create the video clips for me. Your guidance was extremely helpful, and I really appreciate your kindness and willingness to share your knowledge. Thank you again for your support!
