Hello,
I am modelling a simple house and using probably 10 different materials.
I’m trying to purge the unused materials, however I still see over 70 materials in the Materials tab. When I right-click each material swatch, and select ‘Area’, many are showing 0sqm.
Questions:
If the material is covering 0sqm, why does it say the material is being used when I try to delete it?
Is there a way to identify where in my model the materials are being used?
Materials can be applied to used groups/instances/edges none of which will return an area.
Materials can also be applied to entities [like faces] in unused definitions, so best to purge everything in order, with component definitions first, with the layers/tags and materials being the last done…
Materials applied to groups and components do report an area that corresponds to the total area of both sides of faces inside that have the default material.
Here, I painted one face of a 1 m cube red, grouped, and painted the group blue. It reports 10 m² for the blue material
But it is possible to apply a material to a group of edges [no faces], to an instance containing edges [no faces] OR simply onto ‘raw’ edges.
None of these will have an area either.
Some sensible regular purging and the removal of edge materials is probably the best approach to avoid this…
Thanks for your tips guys.
May I ask, in order to follow these purge steps “purge everything in order, with component definitions first, with the layers/tags and materials being the last done”
How do I find the component definitions that are using the unused materials?
i.e. can you provide a bit of a step-by-step? Apologies, I’m still learning.
Thanks in advance.
