2022-02-19T05:00:00Z
You might try SketchUp 2022. SU2020 does not officially support M1 or Monterey.
I will try to find a copy to download. I assume it comes with a CD disk or down load file!
Thanks. Jim
SketchUp hasn’t come on a CD in more than 10 years. Download is available from Download All | SketchUp
$ 229/yr… I use SketchUp when I build a home so I am looking to complete the plans on the home I started on my 2012 Mac Pro. Worked great there but at long last the 2012 went south. I was just told rosetta could be used to make old software run on a M1 anyone try it?
Some people have had success with it. You can try it.
I was just starting a search for it. Is it Mac software are private software?
It is part of the system software. When you run SketchUp 2020 on an M1 machine for the first time, it gets cross compiled to work as an M1 application. That conversion process is what Rosetta 2 is.
In my tests I get close to Intel Mac performance when using Rosetta on M1. So, it would make your SketchUp 2020 run well enough to compare ok against your 2012 machine. Also, the speed of writing to SSD on new machines, and the general design of M1, makes opening and saving files seem faster too.
Is installer failing to load? or, Application failing to start? (MacBook Pro 2017 with Monterey)…occasional “Quit Unexpectedly”.
edit: I’m failing.
time for another coffee
There were three updates to 2017, the last of which was a Mac OS specific fix, in September 2017.
What you say about running from the DMG is a good thing to check.
Whoops, looking at the wrong changelog. Thanks, updated the post
Is this a reply to Mekanic? The way I read his post he has a 2017 MacBook Pro and according to his profile he’s using SketchUp 2021.
It seems I’m getting everything wrong here
Trying to update profile…2022 current version…as of about a month ago.
MacBook Pro 16 “decked out” (M1 and Cores) is some serious $$$$…Trying to follow your M1 progress…and display thoughts.
