Procedural Follow Me
I may just be missing the mark here, but when you use the procedural follow me tool, is there a way to control the materials painted on it?
We need to be able to control grain direction when it comes to moldings wrapping around furniture. Joint/miter lines in the corner are pretty crucial to break up those horizontal planes. Sometimes we need to show a different material in the middle of a molding run. Is there any way to achieve this without making it non-procedural? Kind of defeats the purpose of making it procedural if I then have to explode it to paint it.
The picture below shows the two molding runs that I made non-procedural to be able to draw the miter lines and edit the paint/grain direction correctly. The bottom molding run being what is outputted for procedural.
Editing a material applied to a group created with Procedural Follow Me in SketchUp 2027
Ahhh, so nothing native?
Thanks for the quick reply!
Also, please correct me if I’m wrong, that wouldn’t solve the no joint lines on horizontal surfaces, correct?
(post deleted by author)
Left instance, procedural, grain direction is wrong when molding turns the corner.
Right instance, non-precedural, with user drawn miters to flip the grain direction correctly.
Those corners lack geometry, so you could create a post in the ‘Feature Request’ category to have this added—along with the ability to edit materials using native tools.
I believe SketchUp, by default, merges horizontal coplanars. So when you ‘follow me’, even regular follow me, none of those joint lines on horizontal planes show up. EXCEPT, when you make it a procedure, you see those joint lines in the x-ray preview. So they are there in some compacity.
Alternatively, rather than waiting for that option to be implemented, you can resolve the issue now by moving that vertex vertically by 0.1 cm. There is no visible difference, yet it allows you to edit the texture as needed.
Adjusting the orientation of material on horizontal surfaces after using the Procedures ‘Follow Me’ in SketchUp 2027
That is an option, but as a millwork/cabinetry shop, we have details down to the 1/16th of an inch (0.15875cm). It would start to get confusing of which lines we can trust to build off of and which ones were moved to create a break in the follow me. Especially if its more than one molding.
I appreciate the suggestion!
Profile Builder offers options to miter corners. I’m not sure if the grain will follow.
I set it to 0.1 cm for testing, but I also now tried 0.01 cm and it still works.
However, it’s probably best to wait until they release an update.
For those who only need it for rendering—or for tasks where a value of 0.01 isn’t noticeable—it works fine.
Profile Builder
Profile Builder might have to be the answer. Very unfortunate that procedural follow me is 99% of the way there.
If you are building them for shop drawings : fabrication I would just miter them in pieces like I would build it in real life… then you don’t need to worry about the grain, and you get accurate piece counts.
That is sort of how we do it now, although we don’t necessarily keep piece counts just yet. The accuracy of the grain is crucial to show the client before manufacturing.
But man how powerful would a tool like the procedural follow me could be for moldings to display correctly and give you linear feet for ordering.
You mentioned that the regular Follow Me tool would also not leave the miter lines so your not any worse off with Procedural Follow Me with your molding. As was suggested, Profile Builder would be a good option as it would automatically make each straight run of molding into a separate objects.
Another option that might be worth investigating is TIG’s Split Tools. It can add in the miter lines although it won’t separate the geometry into individual pieces.
Yeah I understand. I think there’s multiple workarounds to get to the end result. With or without the procedural. The end result of it looking correct with miters and textures wasn’t really what I was after. I was trying to brainstorm a straighter path between A and Z.
I guess the goal was to use SketchUp’s new tool in a way that could help us run moldings around our furniture quicker to explore options in the design process. Or even further; to create a dynamic component of some sort that holds our molding profiles with a dropdown arrow that switches our profile and the procedure updates accordingly.
The Procedural Tools are a big step for Trimble, but as a Profile Builder 4 user, I can say it’s way ahead of what SU is delivering. If you haven’t already, read up on it and give the Trial a test. In my experience MindSight’s support is excellent.
Yeah it’s looking more and more like Profile Builder is the way to go on this.
