Hie
I have tryed to finde a solution on a smal but irritateing problem whit “make raport” = i like to export an report to Exel from an framework model, and let Exel calculate the total amont of timber requied for the framework. BUT: Sketchup exports LenX LenY Lenz whit mm included as Exel then gets it as text not an number. Is there any solution to this problem?
I’m on my phone so I can’t check at the moment but if you disable units display in Model Info>Units, does that take care of it?
In excel use find (control f), and replace " mm" with “” without using the “” around the exist and require change
