Here’s a question I feel I should know the answer to!
Layout is the ideal tool for presentation output. It makes it possible to print at a given scale.
There are often times when I find I want to print out, say, just a part of a drawing at a known scale. You don’t really want all the faff of exporting to LO to do just that (if you can help it). Is there a way within SU itself?
If you’re still using sketchup 2021 you can print to scale directly from sketchup, this feature was removed with the latest update in sketchup 2023. Anyways I find it faster and easier to just create a scene, send to lay out and export to pdf or print from there.
In short, Paul, no! But probably because I have missed a trick.
I am on a Mac. I can select PDF output and then change the ratio from the default 1:1 to 1:100 (say). But when I print the PDF, it is not to correct scale. It is more like 1:120. Maybe I did something wrong or some other setting is affecting it.
If it did work, it might be handy, although if you have to create a pdf, then open it, then print it, you might as well use LO.
