Polylines Arc
Anyone tell me why I can’t determine the number of segments (via entity info) of a polyline? When I use the freehand tool to create an arc, I would like to select that arc and increase the number of segments because the arc has about 12 segments and looks ragged. Any help would be appreciated.
Thanks
The segments are listed in Entity Info.
It appears the segment box is only informational. This is likely because a freehand curve is irregular. SketchUp wouldn’t know (easily) how to add or subtract vertices and still keep the curve as drawn.
I’d suggest installing several of the bezier curve extensions. You’ll be able to edit the curves more easily your self.
