Using Pipe Along Path ( TIG: Pipe Along Path v2.2, Awesome plugin BTW ) to create a diagram. In this example if I create the first pipe from A to B, then a second from A to C, I get a smooth transition at the junction D ( no hide/smooth required ). Conversely if I create A to B, then D to C, the junction needs cleanup ( hide, see second image ). Since I have a number of these to create, no extra cleanup would save time. If I choose A to B and A to C, there appears to be an overlap ( maybe just in my mind ) from A to D. Does this double the geometry from A to D? Would prefer to keep this as low poly as possible.
As always, thanks for you help …
