Outliner in SU 2020
In my workflow, the way now Outliner working is really a nightmare.
I would like to give Outliner a try but …
  • normally there are hundreds maybe thousands of objects (groups and components) in my single file, so I have to scroll down and down and down to search for one object, which slow down my work quite a lot.
  • I know I can group objects, but in this case I have to double click in the main window say 5 or 6 times to reach a single object.
  • and to make my object’s organized, renaming objects is a good idea, but I’ve got thousands of them …
I wish I can group objects in Outliner but NOT in the main modeling window. Grouping in Outliner is just a method of organizing in Outliner only.
Or better a real tagging system, meaning that I can apply multiple tags to a single object, not like the tag (previous ‘layer’) now in SU2020.
Hi @ChrisDizon Chris,
Take a look at the images below.
On a daylong usage basis, which one do you think will cause less eyestrain.
I’m curious why adding the eyes in 2020 necessitated creating such visual clutter.
• Omitting the dotted paths makes it hard to follow.
• Especially when the sub-components are out of column as they are.
Kindly add those items to the feature enhancement list.
2019 Outliner
2020 Outliner
Geo
… done
MacBook Pro 10.15.4, SU Pro 20.0.362. In the 2020 Outliner, there is another issue. The number of characters displayed is less than in 2019. In 2010, the limit is 32 characters by my count and in 2019, 122 seems to be the limit. This is a problem in my models since I tend to use very descriptive group instances and nest many components/groups, which means a lot or characters. The unshown characters are not lost since they show up correctly in the Entity Info window, they are just not displayed.
In an earlier post, there was discussion about the new “feature” of showing all components/groups regardless of whether they were hidden or not. One of the solutions suggested was to nest things into other things. Well, you will bump up against this limitation very quickly while trying to work around an unnecessary new “feature” in 2020.
Please put in a feature request to revert back to the limit that was used in 2019.
can you post an example?
Hi Mike,
Attached is an example file with a long named component (SU 2019) and the screen shots from both 2019 and 2020.su outliner char limit.skp (21.0 KB)
Is this a Mac issue?
I downloaded your file and don’t seem to be getting your problem.
I’m on Windows.
It is not uncommon for these things to happen to us Mac users; I have no way to know if that is what happens here, but it does seem likely since you don’t get the problem. Let’s see who else weighs in. Thanks.
I see the same as the OP in SU2020 on Mac Mojave.
Then, it should be reported as bug, I guess, not as FR.
Hi Mike, I created a new topic listing this as a bug and referred to this topic. Unfortunately, I broke one of my own rules and changed the subject in the middle of a discussion. thanks.
This has been logged in our internal bug tracker.
