OnClick dynamic component in network copy of compponent
Hello the company!
Sorry for my english it’s a google translate !
I have a problem with a dynamic component (CD).
I made a network of a slab Surface> Row> Component
I put in attribute on the component
Active
Material
OnClick whose formula is SET (“Active”, 1.0); SET (“Material”; “Turf_Active”, “Turf_Inactive”)
The click on the component changes the value of Active and its material.
Everything is fine !
When I stretch Surface it enlarges my network with the component that copies itself according to rows …
the onclick works well on all slabs except the first of each row.
on the 1st the onClick modifies all the tiles in the row
You follow me or I lost you?
A video ?
https://youtu.be/HInAFmcsqtM
If you have a track so that the first of each row reacts like the others.
Have a nice week end
Simon
Better upload the sketchup file, so we can see what you are up against!
hello
thanks for you reply
in whitch format
SU2008 , SU…,Su 2018
Whitch is the most universal !
https://www.dropbox.com/s/7mdfehqof1azf8k/testGazon_V_SU2008.skp?raw=1
https://www.dropbox.com/s/wdeq6de9kwolr4n/testGazon_V_SU2014.skp?raw=1
https://www.dropbox.com/s/7hcm3i5mrg2apln/testGazon_V_SU2018.skp?raw=1
Simon
Copy 0 of any multicopy component (Copies >= 1) is (conceptually) the “master” copy such that any changes to it propagate to ALL copies, whereas changes made to other copies (Copy >= 1) are applied only to that copy (and any changes are LOST if you change “Copies” in the master!).
Workaround is a bit complex:
  • use 1 more copy than you expect to need.
  • HIDE Copy 0
  • Redo your formulas so that last copy is positioned/rotated in place of copy 0
Thanks sjdorst
It’s a bug or it’s voluntear !
I’ll modify the formula !
I would like to count the componant wich have the attribut Actif =1
The plugin Nested DC of Tommy work only with Su 2014.
Have you an idea to count inside the DC the sum of an attribut ?
Existe an plugin, to cover an area with a grid of componant like my DC.
The idea is to count the number of piece to command and to know the diffrence bettwen (command and posed)
Thank you
Simon
i made the change in formula
if copy =0 hidden
i add 1 in the copy formula
and in the other formula (copy-1)
When i generate a report (SU 2018),
The copy are not count ! :weary:
An idea ?
Simon
