Hey oracles
So I often need to do large layouts with numbers for seats in my venue. Easy, and with the “Number Components” plugin from McGordon (which is a life saver!) it’s quick and really flexible. But now the challenge, how to number my components that are ARRAYED! Image for thoughts…
Maybe OpenCutList help if you send it to Layout or ( save your file before and )…
If you know hot to open Ruby console and you want something as the previous image, try to paste inside this:
module Rtches
module EtiquetasComponentes
extend self
model = Sketchup.active_model
@entities = model.active_entities
@instance = Sketchup.active_model.selection
def comp_ctr(comp)
Geom::Point3d::new(comp.bounds.corner(7))
end
def textinclude (insta)
ar = insta.definition.name
center = insta.bounds.center
top = insta.bounds.max
coordinates = [center[0],center[1],top[2]]
text = @entities.add_text ar, coordinates
type = text.arrow_type=0
text.material = "blue"
status = text.set_attribute "etiqueta", "tipo", "perso"
end
def putstext()
model.start_operation("Añade etiquetas", true)
@instance.each { |i| textinclude(i) if i.is_a?(Sketchup::ComponentInstance)}
model.commit_operation
end
def self.cleantexts()
model.start_operation("Borra etiquetas", true)
@entities.each { |entity|
value = entity.get_attribute("etiqueta", "tipo", "")
entity.erase! if entity.is_a?(Sketchup::Text) && value =="perso"
end
end
end
Then select your components and write this into the console:
Rtches::EtiquetasComponentes::putstext() to put texts
and
Rtches::EtiquetasComponentes::cleantexts() to remove them
hey thanks for that. But I think the plugin Number Components does that great, when groups or components are in a straight line. But how to number them when the array is already in place. Or…I could number them in a straight line, but THEN need to array them, the group+the number?
You might try number rules and scales from sketchucation
Try to select them by circle rows. Then prefix each row with r1_, r2_, etc. The result shoul be r1_1, r1_2, r1__3
