Noob questions from struggling user
I came from 2d cad, and honestly thought this program was beyond me.
I learned tools one at a time (I hardly use some of them!)
You may find the tactic useful too, and btw my maths is not a strongpoint either.
Stick at it, good luck.
There is a free Video Capture/Screencast software called CamStudio that works in Windows. I have used it with some success, although it seems not to like recording sounds in sync (for me, at least).
There is also a nice screen to .gif program called Screen2Gif at https://screentogif.codeplex.com/
I know what you mean. Been using SketchUp for 10-11 years now, and consider myself “very competent” as far as “thinking in 3d” and creating good, clean models, in a fairly efficient manner, but there are so many processes and shortcuts that I have no idea about, and I’m amazed every time when I see people use them to cut time in half – when I thought I was efficient!
For your comfort @pnpn, I still remember the first time someone recommended I use groups, and I had been designing complex interiors for like five years already.
I don’t use SU everyday, but it plays a big part in my “armoury”. It quickly became apparent that I would be no genius at it as there are so many avenues of use.
I like the beauty of the fact that you can be as simple or complex as you like. A rough idea can be put together in minutes, it can be embellished for days depending on what you need.
I’ve come to the conclusion I don’t need to know everything, I probably won’t use it anyway. I need to learn to be more efficient at what I do, and just by browsing this forum daily for the last six weeks Ive learned loads.
It really is a great place to better yourself (even if the odd troll does pop up to rear his ugly head now and again!)
Well said.
I think what’s different with me is that I used to think I was a genius at it, until I started reading the community.
Like the old saying, “When I was young I thought I had all the answers, now I don’t even have all the questions”.
Shep
I’ve done some more stuff. It’s giving me a sore head :slight_smile:
I built a table following a tutorial. That at least was successful.
What’s the best online learning resource you guys know of?
I think this is a good start, there are of course others.
Shep
Hello pnpn…!
The best way to “learn” Sketchup, is when playing not working.
As soon as you set a goal, “to produce a drawing/model”, you have limited yourself.
You don’t have to be “good” at math…you have to be good at figuring it out.
Sketchup is a computer program…it will do math quicker than you…
Heck…it can Only do math…!
So…as long as You Give it the right job…you can “count” on Sketchup…!
Working/Thinking/Drawing in 2 and 3 dimensions, is creative…not logic.
Like imperial versus metric:
“Half of That there” and not “How many units”
The Backbone of Sketchup is referring, infering…
use it as much you can…
Understand: Sketchup is keeping check of it all…even the mistakes…!
There are lots of fine videos on you tube…from woodworkers and architechts among others… people close to your profession…
Matt Jackson have “The digital jobsite”:
Sketchup have a channel:
and there is Sketchup School:
Greetings for now…Jakob.
It’s like riding a bike, start with training wheels (Training videos) practice makes perfect. Once you learn how to ride without training wheels you never forget and the same goes with Sketchup. before you know it you will be wheel standing down the main street.
BTW Sketchuctaion has a book called the Do’h moments. It was written by all of us who realised (years later) a single move, tip, trick or shortcut that could have saved us thousands of hours.
If I can offer my perspective pnpn, as with all software, it can take a while to get into the “head space” of the developers. Also, we all have very different abilities when it comes to visualising 3D space, however if you can reach the point where playing with Skutchup stops being a daunting chore you’ll be well on your way.
For me, my “eureka” moment with Sketchup came once I started using “Components” to control and isolate elements (stop them joining), and even now, the first thing I do is generate a “cube Component” which I can use as my X, Y, Z anchor, or static reference for planes.
Moving on from that, there many ways of generating the geometry you require, but unfortunately, I’m not smart enough to generate an animation for you, but my approach would have been to construct a vertical line from the centre of the polygon and then join the vertices. Those simple “lines” could then be converted to your “hip rafters” or whatever they’re called in a spire.
Hopefully, this sheds some light on your problem, if in no other way than to offer a different perspective on your particular problem.
Good luck
Stick with it! It will start to feel more comfortable and native to you with a bit of practice. Don’t be afraid to make mistakes or not do something 100% right at the first go of it. Making mistakes is the best way to learn and CTRL+Z (undo) makes it easy to undo any “wrong” moves.
The online video tutorials at SketchUp Campus and youtube videos were a huge help for me when I was first learning SketchUp in order to land my last job. Now, I work at SketchUp and learn a little bit more about how it works everyday =)
To ad to the previous comments, watch this forum. I have learned a lot looking at the questions and trying out the answers. Also do a little looking around the net, there is a wealth of training info available. Some of it is free and some requires a credit card.
The mention of CTRL+Z reminded me of one of the things that helped my workflow. When I realized I could assign my own shortcuts to commands that I needed every day, it saved a lot of steps. For example, to my knowledge, the Component/Hide Rest of Model command doesn’t have a default shortcut when you install SU, but it’s something I use every other minute, so adding that shortcut chopped a bunch of wasted time. I recommend figuring out the things you run to the toolbar or the right-click menu for, and learn the shortcuts for them, or assign one if they don’t already have them.
Yes, shortcuts and the ability to set your own custom keyboard shortcuts are FANTASTIC!! I highly recommend new SketchUppers get familiar with the native shortcuts and build out their own. It makes for such a fast and easy workflow.
This ol’ forum post is a good spot for brushing up on shortcuts: Complete List of Keyboard Shortcuts
The Master Sketchup link give an error that it is unavailable or I don’t have permission. How can I get to it?
Either google master sketchup or go to YouTube and search Master Sketchup there?
Hmm, if I right click on the link it will open in either a new window or new tab (Chrome).
You try this.
Shep
Yay! That worked. Thanks!
Sent using Zoho Mail
