I am using sketchup Pro V2019 an am looking for a mini laptop 13" running Windows 10 so that I can occasionally do Sketchup modelling while travelling.
I do not have space for a larger laptop.
I notice that the new mini laptops have Radeon graphics cards.
Are there any users that use Sketchup on such a PC
As far as I know, there is no off switch for it on my Acer Aspire - the Intel GPU is hard wired to operate the internal screen unfortunately.
I talked to NVIDIA about it and they didn’t offer any solutions. Also, the bios has no setting for disabling the Intel GPU.
Strange, mine shows both monitors linked to GTX GPU PhysicsX …
. I would not thought it possible for the Intel GPU to use physicsX.
have you tried unistalling Physics X?
PS… I have just had 3 days or W10 crashes and ended up tracing down one problem being the Intel GPU being set on high performance… … might be worth checking
Uninstalling PhysX does nothing - NVIDIA control panels still look exactly the same.
As for the OP, my advice should be balanced with the experiences of @gsharp - for cheaper laptops beware of the Optimus versions whereas more expensive ones doesn’t seem to be an issue.
Thanks for the input. I will be using the laptop as a travel laptop only. Just need Sketchup to work. Not be the fastest to render. If that makes sense
look for a notebook with a preferrably high-clocked intel CPU and a dedicated nVidia GeForce MX150 GPU, e.g. the concerning models of the following series:
