Need tutorial for this kind of swing door cabinet
example
.Hello everyone, this is my first post here. I need tutorial for this kind of cabinets door opening. Any kind of helps is appreciated! Thank you
Go to the Sketchup campus and SketchUp YouTube
Both offer great tutorials and videos that should help with your questions.
see
Pocket door animate not working? - SketchUp / Dynamic Components - SketchUp Community
this shows concept of action time frame to do multiple moves
door action.skp (22.0 KB)
this maybe close to what you want, however need to match the hinge distances
the hinge model polycount is far too high and out of line, can you post a skimp version with axis in line, prefer with their axis on item parts
do you have an example?
there are extensions that will cleanup and change axis, you need to choose and work what best for you
axis are random and off object, this will not end well with animation.
delete top hinge, as will fix bottom and then copy later
can use styles and temporary choose color by axis to show, draw construction lines and rotate to get correct alignment.
The correct axis position for the hinge will be at the hinge joint, about which it would rotate.
not as you located but
Then check each main part and orientate to match hinge, but at point on component. red to right, green in and blue up. Except screws as will all be same with blue along length, latter to be swapped with same simplified component.
example: from
to this…
