Navisworks import into Sketchup
Hi, can you import a Naviswork file into Sketchup?
We are programming a large commercial project and would like to have a closer look at the building in Sketchup for Buildability and sequencing. The project files are in Navisworks.
We are keen to then sequence the building via a 4D programming software. We have had a look at the 4D virtual builder plugin as an option.
Thanks in advance for any advice.
The NWZ file format is proprietary to Autodesk. Maybe you could obtain the files in the IFC format? I am not sure if the more advanced versions of Navisworks could even export to IFC:
Thanks i will look into the IFC files
