Hello everyone, it’s me again. With the same problem again.
Yesterday, I had to create two *.LayOut files from my Soyez.skp file. Everything was fine until this morning, when neither of them would open, showing the same error message: ‘Unable to open the document’…
I tried going to ‘~/Library/Application Support/SketchUp 2025/LayOut/working’ and saving my *.skp file directly in that folder (it didn’t work). Then I tried deleting the *.skp file named ‘4101671057_Soyez_268.skp’ to try what Colin did — that is, delete the linked *.skp file and open the *.layout file in order to relink it manually.
Mainly to avoid having to come back to the forum and waste Colin’s time having him send me a ‘…MINUS-SKP’ file, and to be able to move forward quickly with my work. But I didn’t succeed.
So I’m asking for your help again.
And if the issue can’t be resolved, is there a trick I could use to create a ‘…MINUS-SKP’ file myself next time, so I don’t lose time again? It’s really holding up my work, especially since deadlines are particularly tight at the moment. Thanks again.
@Colin :
Thanks again for your help. Let me reiterate my workflow, which I believe is correct: I save my SKP file as client_name.skp and send it to LayOut. I duplicate my LayOut pages, right-click on my 3D model, and change the scene. I repeat this process for each page in my LayOut file.
When I need to make changes to the SketchUp file, I make the modifications in the SKP file, save it, then go back to my LayOut file, right-click, and update the model reference. I always follow the same procedure. And I never include a number in the name of my .skp files, so @Colin, when you say :
The .layout file has the Soyez_268.skp embedded in it, and that was done by whoever placed the SKP into the LayOut document
I want to clarify that I inserted the file named Soyez.skp, not Soyez_268.skp. I don’t understand why the file is automatically changed to Soyez_268.skp.
Could that possibly be the source of the problem?
Lien vers les fichiers LayOut
