Mortising and unfolding cylinder?
Can anyone tell me how I might:
Create an array of tenons around this disk.
Transfer tenon location onto this cylinder.
Unfold the cylinder for laser cutting.
(Tried this on my own with multiple errors.)
Thanks!
I assume you’ll be cutting the tenons in to sheet material and folding the sheet material into a cylinder?
Should draw it flat then.
You could try this
Looks to me like you haven’t used sketchup segmentation in such a way as to make it work for you rather than against you.
Make sure your cylinder has the same or at least a corresponding number of segments as the number of tenons you want to create. Then array the tenons so they fall in the center of a flat face/segment.
In reality you can create one segment with the tenon laying flat and make a linear array to get your laser pattern.
Great tip thanks.
The faceting on the circles is still something that makes me avoid SU for this type of work, BUT your tip could change this thanks!
