Modeling with mdkBIM
Ah, I’m starting to get it. If you are able to, add in just a few ceiling joists and strut plates so I can really study this.
There is a lot of extra wood that goes into these hand framed roofs, wow. Lot of respect for the guys that can do this kind of construction, manufactured trusses have made us lazy in some respects.
Okay that is handy extension. I’ve got SU 2024 but I’ve since mostly backed off to SU 2023 since I don’t like that it doesn’t have the ability to save to previous versions and I need that functionality when I’m creating components for the plugin libraries.
I get what you are doing here with the struts, purlins and strut plates. Quite a bit going on here.
In the past we mostly do this:
d057b5889a10db446acb8070207bf15c
Purlin-System
If you mean purlin braces perpendicular to the ceiling joists, I’ve seen it done a few different ways:
  1. Purlin braces connect to a doubled-up or sistered ceiling joists
  2. Purlin braces connect to solid nailers between ceiling joists
  3. Depending on bearing wall layout in room below, ceiling joists are rotated 90 degrees
I will need to spend some quality time looking all of this over and seeing if it could somehow be reduced to some clever algorithms. Thank-you for putting this together.
Version 19:
https://app.sketchup.com/app?3dwid=faf42a98-66af-4024-8c7c-a3ba961e167a
Can you do that and make the required fire separation work for a garage? I guess if you wrapped the beam in fire rated drywall?
Each specific application would be different I suppose. What a particular building department would allow is often a mystery! I worked on some condos putting in large beams that were non structural only for looks. Between each adjoined unit they required continuous double 5/8 drywall firewall and there were framing connections that sandwiched the drywall. I thought it was a bad solution. I would think the fire wall wouldn’t need to pass through the floor system but could be interrupted by the floor. I dont see fire wall required to continue through to the attic space if the garage has a Gyp lid.
mdkBIM Tutorial 6 - Building a Ham Shack
My initial concept of the ultimate Ham Shack (16’ x 12’) designed in SketchUp using the Medeek extensions.
The model can be found here:
My call sign is KK7UXO, but I don’t get on the radio much, mostly I’m programming. :slight_smile:
Some Youtube viewers of this video reached out and told me that they had more equipment than could reasonably fit within such a small structure. I agree, maybe a 16’x12’ space is a bit cramped for anyone, especially if you are also using it for a content creation studio. This is where the parametrics of the extensions come in real handy:
The model(s) can be viewed and downloaded here:
