Missing "Styles" window
Hi, I need your help.
I use the SketchUp 2015 Pro.
It seems that I can’t, anymore, make the “Styles” window appear.
Tabs/Window/Styles, although showing that is checked, no Styles Window appears.
The same is happening with the “Instructor” window.
Thank you.
Sounds like you have change your monitor setup recently.
Can you open Window/Preferences? if so go to Workspace and hit the Reset Workspace button.
Thank you! It worked!
I am using Make 2017 and this procedure did not work. Are styles a Pro option?
No. The Styles panel is also available in Make. Did you look in WindowDefault Tray to make sure Styles is enabled?
Screenshot%20-%209_13_2018%20%2C%204_48_57%20PM
Thanks, I’ll check that next time I fire up my computer. Doug
