Medeek Truss
Version 3.2.8 - 07.05.2023
  • Enabled a ridge centering option for asymmetric gable rafter roofs.
  • Enabled a ridge centering option for asymmetric hip rafter roofs.
I think the non-centered ridge is the more correct of the two, but if you do want the centered ridge then it is also an option.
P.S.
Glad to finally get this monkey off my shoulders. In 2019, I already knew it needed to be done but I didn’t revisit it again until 2021, and now in 2023 I’ve completed it. Better late than never I guess.
Agreed! You may want equal “meat” at the ridge:
It’s impressive to see such active product support and improvement as compared to some of the other CAD software who let their product idle.
Great job Nathaniel!
I don’t think they are letting their products idle, behind the scenes they are constantly developing, and most major software companies have whole teams of developers toiling away. I just try to be very transparent about what I am doing so as to solicit as much user input/feedback as possible.
User feedback really lets me know what is working and what is not. Not to say that I follow every single request, I still take every suggestion and weigh it against my own judgement and whether I feel like it will benefit most of the user base. The other thing that factors in is difficulty and amount of effort required.
I have been working on this particular plugin since Oct. 2015, however my focus has often shifted to other plugins, so at times there is a lull in development activity as my focus is constantly shifting between all the plugins.
You’re probably right. It just gets frustrating when I pay good money to a software company and their focus is interior design and rendering because that’s their biggest customers base instead of accurately generating the components in the model. So many people don’t seem to think it’s important, but a 100% accurate model should be important to everyone, in my opinion. That way everyone can use the model to its maximum effect.
Keep doing what you’re doing. As I become more familiar with SketchUp, I’m sure I’m going to learn all kinds of intricate details that you have in your plug-ins will make my life easy. Along the way I will let you know. Your quest for precision is much appreciated.
Tutorial 22: Asymmetric Roof Framing (8:17 min.)
Centered vs. Non-centered ridges for asymmetric rafter roofs.
Tutorial 23: Licensing and Upgrades (11:59 min.)
Excellent live modeling session today with Aaron, if you didn’t catch it then please watch it here:
With the complex roof module the situation where I have the algorithm breaking down is where the fascia line or gutter line is non-continuous (vertically) around the roof. It is a bit difficult to explain this particular situation in words but the model below presents an excellent example of what I am describing:
COMPLEX_ROOF_STUDY1.skp (1.3 MB)
However after drawing a few more test models and giving it some additional thought I think I can devise a more complicated and general algorithm that will allow for these step ups or step downs. I think the user would start with the fascia line being the same all the way around but then have some sort of option where they can select (multiple) roof planes or along the roof perimeter and then step it up or step it down.
If the step up or step down happens on an outside corner you get a raked hip if it happens on an inside corner you get a raked valley. The only other potential difficulty might be a step in the middle of a roof plane, but for now I am going to exclude those.
Moose antlers?
Its a link to the model in the 3D warehouse but for some reason it is not linking like it used to.
I’ve noticed that in other threads. Someone said you have to use the full “embed code”, I think? I don’t really know.
Tutorial 24: Complex Roof Discussion and Limitations (10:43 min.)
I’m sorry I missed when this happened, but what do the numeric pull down menus for each layer do?
Screen Shot 2023-08-24 at 11.58.09 AM
These are for use with the Layer Control Tool in the Project Plugin:
Version 3.2.9 - 08.28.2023
Fixed a critical bug with the truss removal feature for truss sets.
!!! CRITICAL BUG FIX !!!
I highly recommend upgrading from versions 3.2.7 and 3.2.8.
First time user of the Medeek Truss plugin. Tried the “Complex Roof” function using the trial version and the extension didn’t quite manage to produce a correct truss. I’ve only drawn the outline without modifying any of the parameters. It can be easily reproduced with 6-edge polygons having 4 non-right angles like in the attached screenshot.
There does seem to be an issue when the angles between corners is non-orthogonal (not exactly 90 degrees). I am currently looking into this.
on the complex roofs - rafters are you still working on the ridge and valley rafters?
Ridges are being drawn however I am still working on valley and hip rafters.
