Yes, and the block could always be exploded and the info arranged the way people want it. But at least after going through the trouble to install the data, it could be transferred to the construction drawings. It could be a scene of its own and then referenced in Layout. I think your work on these extensions are the best in the SketchUp realm.
This was just the first cover sheet I came across. On certain projects, we are required to put this info on the cover sheet.
Here is an example of a portion of my old title block from some structural drawings done a few years back. Note that I am missing my email address, but pretty much all of the usual info is present:
I mean I think so.
In Layout, the block of info would be glued in place relative to the model on the page, and it would grow and shrink as you changed the scale of the viewport. You want to be able to move and change the size of the model and text independently. And imagine if you have to edit or simply move the infoā¦
Go to SketchUp
Open the global settings.
Edit info, save
Move/Adjust text as necessary
Update Scene
Save SketchUp Model
Go back to Layout
Resync Layout
Adjust your viewport as necessary.
Done
Or, if the Project info was somehow set up as auto text linked to the SketchUp file.
Go to SketchUp
Edit info, save
Save SketchUp Model
Resync Layout
Done
But if it is drawn and written on the layout cover page as a title blockā¦
Open Text for editing
Done
I think that all the work adding this info to a SketchUp Model will add a lot more work when itās time to go to Layout.
Initially the EOR information was intended for the engineering and site criteria reports (PDF generated) so a title block was not really the original purpose for this information. However, since I already have the information stored in the file (root attribute library) then it makes sense to somehow use this info to create title block etc⦠Hence I also added the AOR information as well.
Perhaps Layout is really the place for title blocks to be drawn/stored, however if one wants a quick and dirty title block shown in SketchUp (plan view), this might be the simple tool for it.
I donāt know Iām still feeling this one out a bit.
That is my thinking with a simple title block, but remember I also have the client information so I could also provide that as well as the designer/architect information. Just trying to figure out what this should show, but I do agree that final construction documents will probably be generated in Layout with a pre-constructed title block that may or may not pull any of the project info from the model.
Note that these title blocks are being drawn in SketchUp not Layout so they may only have limited utility but I think they still may be useful for those wanting to quickly throw together something for presentation purpose.
The Customer, Architect/Designer and Engineers data is pulled as the default but all of this information can be customized completely.
I call this title block a āno frillsā title block, just a functional element that is simply meant to convey the most basic information.
Added the EOR tab to the Project Information tool.
Added the AOR tab to the Project Information tool.
Added the Title Block Tool to the main toolbar.
Added a parametric Title Block tool.
Let me know what you all think of this feature. Again I donāt believe this should replace a proper Title Block in Layout but it will offer a quick and dirty solution in SketchUp for those who donāt need or want to go into Layout.
I should probably also put out a short tutorial video on this feature and how it integrates with the Project Information data.
P.S.
There are probably other things I can do with the Title Block tool (such as add an option for rounded corners) but I donāt suspect it will be used a whole lot, so I wonāt spend much more time on it unless it gets a lot of traction and the user base demands more options and features.
With regards to the layer control and its sliders it was suggested that tick marks would make the sliders more intuitive and easier to use. I donāt disagree however I am finding it quite difficult to find a cross browser implementation of tick marks in a range slider that actually works reliably.
Honestly, a little bit off the beaten path with this latest series of developments since I am not dealing with your typical SU geometry here, but this goes to show that with the full Ruby backend and a built-in HTML browser just about anything is possible with the SketchUp API.
