Measurement Units mismatch in DC reports
I had a closer look at this “bug” and found that if you initially expose the textbox and change the default from text to model units and re-select hide, then the report displays the choice. As you should be aware text is valued as inches unless converted.
Then all works as per report unit choice
del (1).skp (55.4 KB)
