I cant find any information about WHICH one is that ?
The first video can be rendered.
None of them reveals which Extension is involved.
Can you please tell us what is the Name of the Extension, and from where we can download?
This is a plugin I wrote myself, it is only a beta version and has not been released yet.
Ok. Then I moved the topic to right category.
Good Luck, looks promising!
I’ve uploaded it to the EW, but it’s been in the queue for many days.
now u can install this plugin,
the name is ‘rotate texture faster’,
but the version is 1.0,
i have made 2.0 version but not update,added more options .
so u can try 1.0 first.
This looks really good, any chance there will be an update for 2022 soon?
If it worked in v2021 it’ll probably be OK in v2022…
The author has probably not been bother to update the ‘compatibility’ listing…
However, having said that there are several texture rotating and manipulating tools out there…
Look at this as an example…
https://sketchucation.com/pluginstore?pln=TIG-TextureTools
It is upward compatible
As you said, I have tried to be compatible with the old version. but it’s too difficult without API,
Although there are many plug-ins for rotating materials,
But I support the materials out of group or component,
and integrated clear material and replace material tools.
https://ruby.sketchup.com/
Is the main API site, but there are lots of threads about this here and at SketchUcation.com
You are right, it does, i just misunderstood the controls, I was trying to click instead of using the arrow keys.
The EW says it isnt’t compatible with 2022 though, so I was confused.
By the way, when click on an ungrouped plane with the tool it removes the texture on it, don’t know if it is supposed to do that?
Anyway thanks for building the plugin, this wil definitely make my work easier at times.
