Hi all,
Is it a way to make uniq texture with ruby API.
I take a look to makeuniq++ but its require imagemagick.
BS !
Hi all,
BS !
If you don’t want to edit the texture image you can just save it out as an image file using Texture#write, then create a new material and load the image as its texture.
If you want to edit the image I think you need some sort of image library, the thing in the context menu doesn’t seem to be exposed to the API.
Thnaks for your answer eneroth3
Hi all,
I finaly use
@model = Sketchup.active_model
entities = @model.entities
faces = entities.grep(Sketchup::Face)
tw = Sketchup.create_texture_writer
tw.load(faces[0], true)
if tw.write(faces[0], true, "Face.png") == FILE_WRITE_OK
puts("PNG file successfully written.")
end
The image is record with the cropped text
Ok now I have a texture, but I didn’t achieve to put it on a correct position:
I read this post to understand position_material
http://sketchucation.com/forums/viewtopic.php?f=180&t=14611
But its not clear to me.
How control the position a pin with 2 points for each 4 pins?
Its not clear at all for me.
I finally get answer here:
https://forums.sketchup.com/t/rotate-texture-not-on-a-face/14326/2
