yeah, but here is the catch, your pdf describes a situation where the user has the ability to center their view on the place they need.
In my case, I’m not grabbing a 1km2 tiff by choice. it’s the way they are provided, I can’t center on an area or anything, they cut the country in a 1x1km grid. and all I can do is download pieces of it.
When you post newer versions, please remove the old versions. It may also be best if you put the zip (or rbz) archive in the original opening post. (You can edit that post as many times as needed to update the archive file to release new versions.)
The original goal was simple: remove as much friction as possible from the workflow between georeferenced elevation data and a usable SketchUp terrain model.
What started as a GeoTIFF importer has gradually turned into a fairly complete terrain pipeline.
Under the hood, Terrain2Sketch currently handles things such as:
Direct GeoTIFF reading, including GeoKeys and georeferencing
DTM / DEM / DOM elevation data
Float32 raster data
LZW-compressed TIFF
TIFF floating-point Predictor 3
Raster origin, pixel size and geographic extent
EPSG / CRS interpretation
Coordinate transformation using PROJ
WGS84 ↔ projected coordinate systems
Multiple GeoTIFF tiles and terrain mosaics
Geographic cropping by coordinates or address
Adaptive terrain mesh generation
Terrain normals, scale and orientation
GLB export
Automatic import into the active SketchUp model through a small Ruby side
Export of geographic metadata such as bounds, centre coordinates and terrain dimensions
I’ve also been working on a companion module called Sidecar.
Sidecar uses the same geographic reference as the exported terrain and retrieves matching OpenStreetMap context for the area, including:
Roads
Building footprints
3D building context
Water polygons
Woodland / vegetation areas
The idea is that the terrain and surrounding context arrive in SketchUp already aligned geographically and organised into separate Tags.
I’ve been testing primarily with Norwegian DTM/DOM data, but also with USGS elevation data and different GeoTIFF formats.
Terrain2Sketch is currently macOS only. A Windows version is planned later.
I now have a working beta and would be very interested in feedback from people who regularly use terrain, GIS data, architecture, landscape design or visualisation in SketchUp.
If anyone would like to test it, leave a comment or send me a message.
I’ve also made a few short videos showing the workflow, which I can add here if useful.
FYI: It’s pretty easy to turn off all the glass-like stuff. Also, despite all the bruhaha about the transparency, there’s very little of it - because it was a half-hearted implementation to begin with.
In Settings, go into Accessibility and simply click the ‘reduce transparency’ button to On.
