– Making terrain import into SketchUp almost effortless.
Over the past few weeks I’ve been developing a tool that converts GeoTIFF elevation data directly into a ready-to-use 3D terrain model for SketchUp.
Working with terrain in SketchUp often involves several manual steps—processing elevation data, exporting, importing, browsing for the correct file, and waiting for everything to finish.
My goal has been to make that workflow as simple as possible.
Select a GeoTIFF → Click “Export” → The terrain is automatically imported into SketchUp.
The video shows a terrain model from Skien, Norway. From the moment I click Export until the terrain is ready in SketchUp takes about 8 seconds—completely automatically.
The project is still under development, but the workflow is now very close to what I originally envisioned.
I’d really appreciate your feedback.
Would a tool like this be useful in your SketchUp workflow?
Sounds great… if I can get terrain data for Canada!
By release window I didn’t mean release for Windows, but rather the expected release date. I have both Mac and PC, though I do most of my modeling on the Mac.
if you like I can build one for you that you can test.. It´s still in Xcode but it’s no problem to build you a test version. In fact that would be a good help to get your opinion.
Thanks. I’m working a couple of house designs (w/ construction drawings), one is a new build and the other an addition / renovation on an existing house.
It’s the drawings that take the time and (over) occupy the mind!
This is a Canadian terrain that was created with Terrain2Sketch. This was HRDEM so it was nearly 1 gb of download, but it’s a huge area. Actually it’s 10000x10000 meters. Nothing you would normally do but I have to stress the engine a bit . But if you normally work with normal house and extension and so on you don´t need that kind of numbers. And then its s very fast to import terrain.
A lot of the files I looked at in the Canadian web portal was 20 m, but it´s better if you can get 1 m or HRDEM.
At the moment it’s a macOS application with a companion SketchUp plugin for importing the exported terrain directly into SketchUp.
I’m still adding features and polishing the workflow before releasing the first beta, but I’ll definitely post an update here when it’s ready for testing.
Thanks for your interest!
And just for the fun.. here’s a video that is created inside the app from the same mesh as the Sketchup model receives..
