@mkrCAD I have made some ‘homework’ ! In the SketchUp file is a Report saved in the model. This Generates a .csv file which you can relink to the Project Info table in LayOut. (Save the LayOut file as scrapbook and drag in your drawings.
The ProjectInfo.skp contains a Dynamic Component in which you can edit some basic info for your project. By importing the info as tables , you can bypass @DaveR caveat . Every text box is a table which range is limited (context click in layout and select range of .csv )
Drawing number is generated by some formulas , which you can edit in the Component Attributes window. Have fun !!
WF_ProjectInfo.skp (71.6 KB)
ProjectInfo.layout (71.6 KB)
