This previous behaviour is so wonderful isn’t it…
Seriously, for a few seconds earlier today, I felt like ignoring my work and deadlines and porting a current 2026.2 project into 2017 to see if I would miss nearly 10 years of Layout development!
Yeah or maybe can we turn off the feature that causes Trimble to mine an entire bitcoin with my gpu every time I resize a viewport by 1 inch? You’re asking for icing when we don’t even have the batter to the cake yet.
Well – I could reply with what I think about that but I would cause uproar from other users!
And it’s not icing!
It works like that in Version 2025, has it changed in V2026? I’ve been holding off on installing the latest as I cant break a working worflow!
I’m leaving LayOut to create an alternate of LayOut, it’s called 5D+ Paper. It let you not moving any where, just right inside SketchUp. Also, it will have what LayOut is missing:
Wow ![]()
Directly in SketchUp
(How is that possible !?)
Do you have a website for this??
Technically this is double posting. Better etiquette is to post a link here to the corresponding post in your thread dedicated to the subject. Then there isn’t duplication of effort and discussion.
Thanks for your noticing, I edited the post.
The low-hanging fruit improvements to layout hang so low that the tree is collapsing under the weight of the fruit. It’s just not an operational priority. Never has been, never will be. Not enough people use it.
Has anyone looked into what the layout file actually is? It’s a zip file. Literally, you can rename any layout file with a .zip extension in Windows and open it as a zip archive. Here’s an example:
example.skp is a fairly heavy model, mostly due to textures. Our company does commercial interiors and we build the sketchup model by importing raster images of the architectural drawings as backgrounds to model based on, and those raster images are the big majority of the 13,323kb of the file. It’s probably under 10k total SketchUp entities.
example.layout is a set of 11x17 documents. 13 pages 20-25 viewports total. Mostly hybrid and raster mode for the viewports.
The folder is that layout file, renamed to zipped, and extracted to a windows directory.
At the top level of the layout file are xml files containing information about references, and seems to contain all of the drawing data for any placed layout object, such as a viewport, dimension, annotation, or layout geometry. Nothing super egregious here except that its xml in 2026. styleManager.xml seems like too much data to describe what it does. There are a lot of (seemingly unnecessarily) deep nested keys like.
<t:dicItem key="dimension.leaderline.dimension.dimensiontext.dimension.extensionline1.dimension.dimensionline.label.body.arrow.end.type">
<t:variant type="2">0</t:variant>
A capable tech enthusiast could probably improve this by quite a bit with a day and some help from Mr. Claude Code, but meh. /pages is similar.
/vectordata contains xml of vector data for each viewport
A small part of one of the files
<n0:path id="id468" rotationAngle="0" requiresStrokeOrFill="1">
<n0:graphicEntity shouldFill="0" strokeWidth="0.30000001" strokeJoinStyle="1" strokeCapStyle="1">
<n0:entity/>
</n0:graphicEntity>
<n0:elements>0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1</n0:elements>
<n0:points2f>6.821892,5.825516,6.821892,5.747391,6.821872,5.742478,6.821892,4.591141,6.821892,4.497391,6.821892,1.981766,6.821872,1.966141,6.821872,1.93047,6.821872,1.912016,6.821872,1.869447,6.821872,1.848449,6.821872,1.798142,6.821872,1.763016,6.821872,1.75059,6.821872,1.747391,6.790622,1.747391,6.546379,1.747391</n0:points2f>
</n0:path>
<n0:path id="id469" rotationAngle="0" requiresStrokeOrFill="1">
<n0:entity/>
</n0:graphicEntity>
<n0:elements>0,1,1,1</n0:elements>
<n0:points2f>6.821872,1.747391,14.82968,1.747391,14.82968,1.497391,6.546379,1.497391</n0:points2f>
</n0:path>
<n0:path id="id470" rotationAngle="0" requiresStrokeOrFill="1">
<n0:entity/>
</n0:graphicEntity>
<n0:elements>0,1</n0:elements>
<n0:points2f>6.546379,8.247391,14.94579,8.247391</n0:points2f>
</n0:path>
<n0:path id="id471" rotationAngle="0" requiresStrokeOrFill="1">
<n0:entity/>
</n0:graphicEntity>
<n0:elements>0,1,1</n0:elements>
<n0:points2f>6.546379,7.997391,6.790622,7.997391,6.790622,1.747391</n0:points2f>
</n0:path>
The problem with this is that the data is extremely flat and unfolded with each and every line segment having its own unique set of metadata like strokeWidth, fill, etc. If you open any svg file in a text editor you’ll see that the objects are lumped together when they have matching metadata attributes. Maybe (hopefully) the Layout program is doing something efficiently like that with this data when it initially loads the xml files rather than walk down the dictionary of each and every object but given the performance issues with the app, i kind of doubt it.
Saved the worst for last. The main reason why the .layout file is so large is that it creates not zero, not one, but TWO fully-redundant copies of the skp file in its zip archive. I can understand if you had a toggle setting to make the layout file a package that can be opened without the skp. And then it also keeps all of the png files, one for each viewport. So when you’re lumbering around through the sheets and layouts sweating bullets trying to draw and redraw all this stuff, just remember that it has the skp file (two copies of it for some reason) available to it, probably in working memory, along with pre baked pngs at full resolution for every viewport.
I’m sure I’m just not tech savvy enough to understand why any of the files in /ref exist at all. Why not just have a 2mb file, draw the viewports at runtime, and actually ref the skp file in the working directory?
Many times.
Don’t even have to rename it to .zip to open it.
How did you insert the SketchUp file into LayOut? The only time I’ve seen what look to be redundant copies of the SketchUp file in the LayOut ref folder it’s because the user has copied from SketchUp and pasted into LayOut multiple times. This isn’t good practice and there’s no reason to do that anyway. None of the LayOut files I’ve created in 18 years of using the program have redundant .skp files in them.
It was probably cloned from a template so I’m honestly not sure. What is the best practice for referencing an skp file in layout?
Either send the .skp file to LayOut via File>Send to LayOut or use File>Insert in LayOut. If you have a template that has a proxy SketchUp file, don’t use either of those methods. Instead open the template in LayOut and in Document Setup>References, highlight the proxy .skp file and then use Relink to select the project file. No matter which way you insert the .skp file, after you have the first viewport just copy it and paste it as needed to make the rest of the required viewports.
@daver Thanks. I was able to fiddle with the example file and purge it down to having one redundant nested skp instead of two. It was probably one of my guys who inserted the 2nd copy at some point along the way.
If any modern workflow requires a live skp file in the directory (yes), then it still makes no sense to contain that file. Especially when PBR textures increase the size of sketchup files by orders of magnitude and stuff.
If there was no reference .skp file contained within the LayOut file and the SketchUp model file gets moved or deleted accidentally, the LayOut file would become trash. With the embedded copy of the reference that’s not an issue. The same applies to inserted images, text files, and spreadsheets. LayOut compares the embedded copies with the references to know when the references have been updated. Otherwise there’d be no way to tell. At that point you might as well just export images from SketchUp and insert those into a Word document. Another benefit of having reference copies incuded in the LO file comes to play when you need to share files. For example, you could send me your LayOut project as a single (zipped) file and there’s no need to remember to send the SketchUp file, too.
Good incentive to keep SketchUp models clean and streamlined. If the PBR feature isn’t required in the model the extra maps can be removed.
I ‘Send to LayOut…’ several times per day - my proxy file is basically my SKP template (or one of them) - when I send a model to LayOut it updates the proxy, no need to re-link it or anything.
It hasn’t always worked that way, though.
I think there are plenty of examples in other arenas of having dependent reference files as the single source of truth with options to create a shareable package that contains those dependent files. Autocad xrefs aren’t doubled up to bloat the dwg file containing the reference, and that’s been the case since the 90s. The whole point of passing by reference is to avoid this. Or just do what @cyentruk is doing and have it all be contained in the app. Have a sketchup lite that just works with skp and let sketchup pro open just the layout file and become the all in one workstation. Then it might be a first class citizen and have the performance issues addressed.
Any of those seem preferable to having a bastardized sibling app that gets no support and doubles or triples the size of the working data.
For me Layout is already…
…apart from the behaviour I describe at the beginning of this thread, and of course the bugs.
