I have scenes in sketchup that I am referencing in layout. I have a lable/leader attached to it (in layout) that I am using to display what the scale is.
I typically use scales that are in the dropdown menu. (1/4" = 1ft, 1" = 40’, etc.). When I use these options, that leader correctly displays whatever scale my viewport is at.
However, right now, I want my viewport to basically fill the page. This puts it at an odd scale. Specifically, 1:139.968. The leader will not display this value. Only says “not to scale.” For this specific application, I don’t like the next smaller (1:128) or next larger scale (1:192).
Is there a way to make it display the scale/ratio when it’s not a “standard” scale?
Share the LO file so we can see what you’ve got. Most likely you would need to add the scale to the Scale list so there’s something for Auto text to work with. In the case of your example round it to 1:140.
