LAYOUT - dimension - transparency
I use "center " dimensioning style with Layout and up to version 2023( I think) I was able to use a transparent background with it.
In the latest versions however, the line is continuous underneath the number.
I would love to know if there is a way achieve the same result as I did in previous versions…
"Centre " Style dimensioning with transparency -Sketchup 2023 and earlier versions
"Centre " Style dimensioning with transparency -Sketchup 2024 and newer versions
are you using the new or the old engine in your second screenshot ?
does switching engine changes the result ?
It does it in both engineers.
I filed a bug back in the 2023 or 2024 beta release. Not sure if it will make it into a release. I’ve had to switch to solid fill in dimensions when needed because of this.
Thank you.
Yes. I think I flagged it back then, when it was changed. but nothing happened…
I also switched to solid background, but would preferer to use transparency…
Is there a forum where I could flag theses minor issue for improvement? I feel that a lot of little improvements could really speed up our everyday work. The once which are probably not too difficult to fix or add…
in here I guess
