Jet Brain RubyMine 2023 Remote Debug
Hi,
Years ago I was working on SU2017 and I managed to setup the RubyMine 2017 remote debug following the instructions given on this community. That worked perfectly and that was really useful !
I tried to configure the SU2023 remote debug on RubyMine 2023 but that’s clearly different, close but different on the interfaces. Finally I didn’t manage to make it work.
Does anyone has some explations regarding theses ? I found some explations on JetBrain: Remote debugging | RubyMine Documentation.
I hope you could help me, that would be really useful and much more comfortable for debugging Plugins development.
Thanks for your help !
Hi all,
I’m back again and I found the solution. I reopened the RubyMine Debugger Setup that I used to setup connexion between RubyMine 2017 & Sketchup2017
The thing to precise is product evolved and image capture re not up to date + some precisions :
  • Remote root folder : Where the code you’re running is stored, Sketchup Plugin Folder or a specific Folder.on the Computer you’re working if it’s the same machine.
  • Local root folder : Same comment as previously.
  • Use the Sketchup 2022 Ruby Debugger for Sketchup 2023 (Releases · SketchUp/sketchup-ruby-debugger · GitHub)
If you have any other questions Email me privately.
Cheers !
To make a summary ok items that could be usefull:
RubyMine Project Setup
SketchUp Ruby API Debugger
SketchUp Ruby Debugger
Guides
New infos relative to Mac M1 versions. Usually the Sketchup APP crash when loaded into the remote debug. It’s related to the lauching network port 7000 an can be solved by using the port 7354 (validated on my side with a friend working on a Mac M1) :
Thanks to Ruggiero Guida !
hi milmandre Are you available to take a look at my debugging issue
