Is SketchUp Make SU 2017?
I am trying to install Fredo6 Animator into SketchUp Make using the SketchUcation auto install tool. The tool says the plugin is installed, but it doesn’t appear anywhere?
The plugin info screen says it needs SU2017 and above, so I wonder of SketchUp Make is compatible?
The same thing happens with LibFredo6 and Joint Push Pull.
As to plugin compatibility, the old SketchUp Make 2017 is the same as SketchUp Pro 2017.
Thank you @Anssi
I must be doing something wrong then. I usually download plugins to my PC and install them from the Extension Manager, but I am trying to install them using the SketchUcation tool after reading that’s the correct way to do it.
Just tried loading Lord of The Toolbars as well with the same result.
I need to wait for @DaveR to wake up :grinning_face:
I have now installed Animator in SU Make 2017.
In this case, in SU Make 2017, install from Extension Manager. SketchUcation extension shows you that it installed but in fact it didn’t work.
And, of course, restart SketchUp.
Thank you - everything works great now :+1:
This topic was automatically closed after 180 days. New replies are no longer allowed.
