Is there a way to customize the keyboard shortcuts on the iPad? I see that this ability is added per the release notes, but for the life of me i can’t find a way to do it.
(Release Note section pasted below)
Keyboard Shortcuts
Shortcut symbols now support localized languages, enhancing usability for non-English users.
Modifier key combinations are now also supported when setting shortcuts
Locate the help button (?) at the lover right corner of the screen and click on it.
Select the first menu: Search. (Its called also as Omnibar… whatever its means…)
(Or locate the Search button at the toolbar)
Start typing a command you want to modify and its shortcut will appear at the right. Simply select this and type a new.
(Tip: You can reset all shortcut to default by click on the gear icon on the top right corner of this diallage)
