Buenos días aunque me he bajado el programa en la versión española me lo instala en ingles . Saben cómo solucionar esto
Gracias y saludos
Gracias y saludos
Did you get it from here ?
Yes. I downloaded the Spanish version here (SketchUpPro-es-x64.exe)
but it still keeps coming to me in English.
What is the language of your operative system? I think SketchUp uses English if that’s the system language regardless of what installer you use. I’m not sure though since I’ve never tried any of the translations myself.
This is correct, SketchUp will follow the language settings of your operating system when you start up the application. All installers include English resources. I’m not sure if there is a way to force it to display Spanish but keep your system language set to English.
You can on Mac: download the Spanish version, then launch from Terminal via:
SketchUp -AppleLanguages ‘(es)’
Puede modificar el campo “Objetivo” del acceso directo de escritorio para agregar el parámetro de idioma.
Así que el camino para usted será:
“C:\Program Files\SketchUp\SketchUp 2017\SketchUp.exe -lang=es”
You can modify the desktop shortcut “Target” field, to add the language parameter.
So for you it would be:
muchas gracias. ya he solucionado el problema
