When i import 2013 dwg file to sketchup 2015 free trial ,the lines seems to be not perpendicular and the curves as if they are broken lines ,please help
hello, can you send the dwg so I can have a look at it ?
Are you trying to use a too small import unit?
All arcs and circles are segmented in SketchUp. The 3D objects in SketchUp consist of flat faces that need straight edges to form. You can control the segment count in the Entity Info panel.
Thank you all , the problem solved by purging acad file and explode for the plan and import it again
