3D dwg file to sketchup
Hello, i imported a dwg file that contains curves into sketchup but here the curves are angular. I tried deviding one curved line using the devide function but it did not help. Is there any solution please?
If you want to divide a curve you need a plugin, fredo tools has a divide edges tool, also fredo spline can divide curves in some ways.
thank you very much
What version of SketchUp are you really using? Your forum profile says you are using the free version but SketchUp Free does not have the ability to import .dwg files, nor does it have the ability to use extensions.
SketchUp Pro 2023 Trial version
That’s not the “Free Plan” then. It’s SketchUp Pro. Please correct your forum profile. That information helps us help you but only if it is correct.
i am
sorry i will fix it
